Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Installation instructions for ground effects kit Gen 5.5?
View Single Post
Old 11-24-2007, 04:31 PM   #10 (permalink)
TRD VVTi
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Originally Posted by scamry View Post
uhmm....my spats had little brackets on them that line up with existing bolts on the bumper (or the plastic under the bumper, i dont remember....its been a year....) but it was pretty much hold the spat up to the bumper and you could see the hole where it should line up...if i remember correctly.
The front spats do have a flimsy plastic bracket that does line up with a fastener for the lower/under car splash shields. However, there still has to be a hole drilled for the rivot at the end of the spat towards the center of the car. There is also a screw that gets installed in the wheel well. Double sided tape is also used where the spat contacts the bumper cover.
Basically, the front spats, side skirts, and rear spats are all installed the same way.
2006 Camry LE Special Edition
