Source for pins
I successfully used pins from the connectors used on PCs to attach USB ports to the motherboard. I extracted a few from a connector and made a 5" pigtail with each, which I then soldered to the wires from the Eclipse camera. A bit of electrical tape to cover that up (perfectionists should use thermal-shrink tubing instead), and I pushed the pins into position in the B10 connector using the tip of a straightened up paper clip. The picture came up as soon as I engaged the reverse, no need to reset anything.
Thanks to all the posters for their invaluable advice.
