ooh oops were you asking about the gauge cluster or just the middle console panel in your first post?
In any case, the middle center console where the radio and HVAC controls are is easy too if I remember correctly. Remove the ashtray and the cigarette lighter. Then, using a flathead screwdriver with a towel, insert it anywhere along the trim that surrounds the hvac controls and it should pop off. Oh yeah, you might as well pull the hvac knobs off as well. Then, once the trim is out of the way, you should be able to see the screws that hold the hvac unit in place....remove them and out comes the hvac unit. However, I've never tapped inside the unit itself to see if the bulbs are reachable. If you dare try it, let us know with an update
Thanks
