cosmic - u can just use a bike cable. get something that is long enuff so it reaches the driver side. dont forget to get some crimps so that u can use it to make a loop where the chokes are. Then try to pull it and see if it works properly. Install some return springs with light tension so that its just enuff to go back to normal position. Im not sure where u from but if its not cold in your area you maybe able to live without using the chokes coz we dont really use them unless its very cold.
hope this helps
Ridez..
94 Mitsubishi Pajero
81 Toyota Starlet (3S-GTE 3rd Gen BABY !!)
