Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Bizarre Fueling Issue
View Single Post
Old 12-03-2007, 09:06 PM   #9 (permalink)
toyomoho
View toyomoho's Photo Gallery
The fuel tank has a vent tube that routes trapped air back into the upper part of the filler hose. If this vent is plugged the gas will enter slowly and the fuel nozzle trip.
The charcoal canister absorbs gas fumes from a closed gas tank then purges them to the engine to burn. The fuel nozzle of the gas pump may have a system to pull off the gas emissions as the tank fills.
If you do need emissions parts try www.rockauto.com. Changing the canister is a DIY job.
