Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1996 Camry Driver Door-Open Switch or Sensor
View Single Post
Old 12-09-2007, 11:23 AM   #2 (permalink)
dc_98_cam
The Gen 3 wiring diagram ...you can download from top of forum page .... shows that the front LH door unlock detection switch is contained within the door lock motor unit. ... p.161.
The wire that goes between the detection unlock switch and the door lock control is light blue with a red stripe. ...If you can visually trace and inspect this wire, you might find a break or maybe some bare insulation .... Also, a frequent problem appears to be broken or bare wires in the door hinge area ... which require opening the rubber boot to be able to discover them.
The diagram also shows a white wire with a black stripe going from the door lock motor unit to ground ..... probably check this also.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
