Wow - thanks for that bit of information. I never noticed that piece and would have assumed that it was simply a rubber absorption bumper for when the door closes.
I assumed that the problem had to be with the wiring inside the door somewhere since this all began when I brought it home from the paintless dent repair.
I'm sure your correct that the problem is with that switch. Knowing that that is the switch, at least I can manually duplicate the problem, and will know when I get it fixed.
I'll do as you suggested and get back to you with a confirmation.
thanks much!
