EGR valve '96 ES
I removed what I think is the EGR valve assembly - (5) 10mm nuts but I don't see what I can clean ?
The manual says "check valve for sticking and heavy carbon
build up". There are two tubes but they look ok... not clogged.
I removed the whole thing and I think the valve is the round piece with the single vac line attached. If so, how does that come off ? I don't see any screws or bolts that attach it to the cast iron piece ? It's next to the vac modulator.
thanks,
Bob
P.S. - I was getting an EGR "restricted" code a few months ago and now
it says "excessive" so I assume my problem is the EGR valve.
