Tried to clean air intake sensor, now car won't start. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 11-23-2005, 10:16 PM   #1 (permalink)
View drdu's Photo Gallery
Tried to clean air intake sensor to my 2000 RX 300 with carb cleaner solution and Q tip. Thought the sensor was giving a false reading of too lean of fuel mixture. Another poster says too much air is the cause. At any rate, the car runs for 5 seconds and dies out. I don't see anything disconnected from the air intake manifold and the filter has been changed. What gives?
drdu is offline   Reply With Quote
Old 11-24-2005, 12:48 AM   #2 (permalink)
View leasaunce's Photo Gallery
did you put the MAF sensor back properly??? how much did you put in??
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 11-24-2005, 02:01 AM   #3 (permalink)
Never took it off. Just lifted the airfilter box and took a Qtip with carb cleaning solution to swipe underneath. Qtip was black as can be. I didn't notice any hoses that were loose but I did disconnect the wire harness plug to the sensor. Could that have triggered something in the computer?
Old 11-24-2005, 11:37 AM   #4 (permalink)
View Silver-Bolt's Photo Gallery
Any time you work around the MAF sensor disconnect the negative battery terminal. Check your MAG connection. If all your connections are good try this. Disconnect the neg battery terminal, step on the brake pedal 3-4 times to drain any residual voltage in the system. Reconnect the battery and restart the car. How dod you know you have a lean condition? Did it throw a code?
06 Taco 4DR TRD-Sport
08 VW R32
04 Subaru STi (377whp)
00 Ford Lightning (528whp)
04 Aprilia Tuono Factory & Aprilia SXV 550
Silver-Bolt is offline   Reply With Quote
Old 11-24-2005, 10:38 PM   #5 (permalink)
Yes it through a code saying the fuel mixture was too lean. If the mixture was too lean, could it be a possible hose crack allowing air inside a line? I would disconnect the EFI fuse to reset the engine off but after driving around a hour or so the light comes back on.
Old 11-26-2005, 10:18 AM   #6 (permalink)
The Asian Sensation
View Xevuhtess77's Photo Gallery
check the connections on your maf.
if you've ever tried to start a car without plugging in the maf before, it does exactly that. starts right up then just dies right after.
Xevuhtess77 is offline   Reply With Quote
Old 12-13-2005, 08:39 AM   #7 (permalink)
Podiatrist
Underwhere's Avatar
View Underwhere's Photo Gallery
Your maf doesn't read lean or rich.
It reads the volume of incoming air.
Anyway, I would double check your connections. It sounds as if the MAF is not connected.
The ECU does not ever store in memory that the MAF was disconnected. So no need to disconnect the neg terminal and stomp the brakes.
The MAF is basically a heated wire. You don't need to worry about static electricity or anything.
Underwhere is offline   Reply With Quote
