1992 ES300 gas fume smell - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 12-20-2005, 09:37 AM   #1 (permalink)
View Montanahelp's Photo Gallery
I have a 92 ES300 that has developed a strong gas smell that is coming inside of the passenger compartment. I noticed appear while starting up the car in cold weather - @ 10 degrees. Could a vapor canister be frozen or malfuntioning? I don't see any gas leaking on the ground.
Montanahelp is offline   Reply With Quote
Old 12-20-2005, 09:23 PM   #2 (permalink)
View bob95603's Photo Gallery
You wouldn't see gas on the ground unless you had a lot of gas leaking. Look at the engine to see if their are any wet spots. With a '92 (agewise) I'd suspect you probably have a leak at a fuel injector. Check the base of all injectors and you'll probably find a leak.
bob95603 is offline   Reply With Quote
