Scraping noise from front passenger side - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 02-13-2006, 05:27 PM   #1 (permalink)
View NathanOfSeattle's Photo Gallery
My 1997 ES300 with 75K miles on it has an awkward scraping noise coming from the front passenger side area. Applying brakes or not applying brakes does not change the noise. It also happens when going at lower speeds (forward and reverse). However even then, the noise is intermitten. Does anyone have any idea what may be causing the strange noise?
NathanOfSeattle is offline   Reply With Quote
Old 02-14-2006, 03:21 AM   #2 (permalink)
Woogee's Avatar
View Woogee's Photo Gallery
Hmmm this is a stab in the dark, but check out the wheel bearings.
Woogee is offline   Reply With Quote
Old 02-14-2006, 01:16 PM   #3 (permalink)
That's a good idea. But could you explain what exactly I would be looking for?
Old 02-16-2006, 01:24 AM   #4 (permalink)
View KS_Hicks's Photo Gallery
I believe there is a metal shroud behind your rotor. If you had any brake or wheel work done lately, sometimes it will be slightly bent to where it is rubbing against the backside of your rotor. In this case all you have to do is gently pull is back some. This happened before on my ES250.
KS_Hicks is offline   Reply With Quote
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Passenger side a/c cooler than Driver's side??? 3vz4me Camry & Solara Lounge 8 03-08-2006 07:42 AM
Scraping Noise on right front tire/brake crabby Yaris, Vitz and Echo Forum 2 01-31-2005 07:08 AM
