99 Lexus ES 300 Starting problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 03-04-2006, 05:13 PM   #1 (permalink)
View dgoude266's Photo Gallery
I have the above car with almost 90K miles on it. Twice in the last few months I have tried to start my car and it will turn over and crank, but as soon as I let go of the key and it falls to the start position the idle doesn't catch and it shuts off. The first time I had it towed and the next morning when the shop opened they called and said they got in the car and it started right up. After that it ran fine for two months then I got in it today and it did the same thing. This time when it didn't catch, I let it sit for an hour then went back out and tried again, same thing. So I cranked it again and red lined the RPM's and when I let off the gas it stayed cranked. Anyone have any idea what could be causing this?
dgoude266 is offline   Reply With Quote
Old 03-06-2006, 04:23 PM   #2 (permalink)
Woogee's Avatar
View Woogee's Photo Gallery
Fuel Delivery problem maybe? Check fuel pump and fuel filter. That or try checking the Idle Air Control valve ( i think that's what it's called) on the throttle body.
Woogee is offline   Reply With Quote
Old 03-19-2006, 01:39 AM   #3 (permalink)
View The Car Newbie's Photo Gallery
If the temperature has been a little cold then i would reccomend putting thinner oil in it. Oil gets really thick in cold weather. In the summer change to thicker oil so you dont ruin your engine.
The Car Newbie is offline   Reply With Quote
Old 04-13-2008, 05:14 PM   #4 (permalink)
View mk3turbo's Photo Gallery
i got the same problem but only if i park it on a down hill
mk3turbo is offline   Reply With Quote
ES 300 Not Starting Autovirgin General Lexus Discussion 10 02-06-2005 02:06 PM
Starting problems - Electrical. pdrover Archived Corolla threads 12 02-09-2004 03:55 AM
'99 Tacoma starting problems GuitarCharlie 1st Generation (1995.5–2004) 3 10-20-2003 06:59 PM
92-96 lexus es 300 body kit skperformance General Lexus Discussion 4 02-07-2003 01:44 PM
