1990 ES250 Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 03-12-2006, 06:07 PM   #1 (permalink)
View Entropy's Photo Gallery
Hi guys and gals,
Newbie question(s) for ya. I'm servicing a 1990 ES250 for a lady in our church. I already found a post that told me to pull the upper intake plenum to access the back spark plugs, done. How about replacing the upper plenum gasket? Do I need to purchase a whole intake set or can I clean the old one up, assuming it stays in one piece, and just use a spray type sealant?
2nd question. I tried to pull out the diagnostic codes frim the ECM, I got a contiuously flashing check engine light, about once every .5 seconds. Is this an all clear signal?
Any insights and ideas are appreciated.
In Grace, Entropy.
Entropy is offline   Reply With Quote
Old 03-12-2006, 07:03 PM   #2 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
You probably should replace the gasket but doesn't have to be
As for the codes, when they start flashing then you have to follow the pattern
example c c c c c c c represents 34
c c c c = 12
they will blink fast and then a pause and then fast again to represent the first and last digit of the number
but watch closely because it may have more then 1 code in the memory
hope this helps
BadChicken is offline   Reply With Quote
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
OK..how do you change spark plugs on a Lexus es250? LeXuS2Nv General Lexus Discussion 3 06-03-2005 02:17 PM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
1990 Camry,Need help replacing spark plugs!? johnt98 1st & 2nd Generation (1983–1986 & 1987-1991) 3 04-15-2004 08:42 AM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
