Help turn off maintenant light IS300 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 06-08-2006, 01:56 AM   #1 (permalink)
View xony75's Photo Gallery
Could anyone help me how to turn to maintenant light off. my baby is 2004 is300 (no warranty from lexus) so lexus dealer is not an option. That light drive me nutzzz
xony75 is offline   Reply With Quote
Old 06-09-2006, 11:41 AM   #2 (permalink)
View txleex08's Photo Gallery
check engine light? if so, just disconnect the neg terminal of your battery for about 20 minutes and connect it again, this resets your ecu.
txleex08 is offline   Reply With Quote
Old 06-10-2006, 07:25 AM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
No, maintenance required. It's a reminder light to get services performed. The check engine light tells you something needs repairing. I wish I could tell you the trick to reset it but I haven't had to on a Lexus yet. Please share with us if you find out how.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 06-12-2006, 12:13 PM   #4 (permalink)
View lclexus5's Photo Gallery
i would try the battery connector, or find the fuse for that light. The light could be going out so sometimes that is a reminder if it does not shut off.
lclexus5 is offline   Reply With Quote
Old 07-04-2006, 10:52 PM   #5 (permalink)
View digger08's Photo Gallery
ENGINE OIL REPLACEMENT REMINDER LIGHT
The system must be reset after the engine oil replacement. Reset the system by the following procedure:
Turn the ignition key to the "OFF" position with the odometer reading shown.
Turn the ignition key to the "ON" position while holding down the "ODO/TRIP" button. Hold down the button for at least 5 seconds. The odometer inidcates "000000" and the light goes off. If the system fails to reset, the light will continue flashing. In this case return to step 1 and try again.
regards
Digger08
Digger08
Lexus IS300
01' Onyx/ Arm Rest/ 02 Tails/ Xpel/ Carson Tuned/ Eibach/ Ltuned 18's/ Injen Intake
GReddy EVO/ TeCk grounding kit/FigProprod/DashTray/ LSD/Ltuned Sways
digger08 is offline   Reply With Quote
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
Bulb size? Ramenx 2nd Generation (2005+) 34 02-28-2006 12:11 AM
Braking in the snow and light turn on CX889 Camry & Solara Lounge 0 12-05-2005 12:31 AM
Question Bulb Type for rear turn signal cman2000 Camry & Solara Lounge 3 03-24-2005 10:53 PM
corner light -> turn signal conversion jwa276 Camry & Solara Lounge 6 01-09-2002 01:25 PM
