Reading Engine Diagnostic Codes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 06-18-2006, 12:30 AM   #1 (permalink)
Toy Newbie
View hdygma's Photo Gallery
Can Someone help me. I'm a newbie to Toyotas. I have a 97 ES300 that I would like to read the engine codes. I don't know where the OBD-ll connector is located and how to pull the codes. Cars I've driven in the past have allowed me to turn a screw on the ECU and the MIL light would blink the codes out. Thanks.
hdygma is offline   Reply With Quote
Old 06-18-2006, 12:34 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
did you try looking under the driver's dash board... where the chang box is, but under it, as in under the dash
The screw or the paper clip thing won't work, but you can go to your auto parts store and they could possibly read the code for you. Or get one yourself, it's about 100 bucks these days.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 07-28-2006, 06:21 PM   #3 (permalink)
View Miracle Engine's Photo Gallery
The OBD-II connector is behind the fuse pannel on the left side of the steering wheel. You should use the scan tool to get the codes but if you need to pins to jump let me know and i can look it up for you.
Miracle Engine is offline   Reply With Quote
Old 07-30-2006, 11:45 PM   #4 (permalink)
View toyomoho's Photo Gallery
Autozone stores supposedly will read the codes for free.
Old 08-02-2006, 10:11 AM   #5 (permalink)
View alflash's Photo Gallery
Hi,
You can read the diagnostic trouble code from malfunction indicator lamp: Using suitable wiring, connect between terminals 13 (Tc) and 4 (CG) of data link connector No.3 (aka OBDII-connector, http://www.alflash.narod.ru/Learn/dlc.gif ) or by connect between terminals E1 and Tc of data link connector No.1 (under Hood, http://www.alflash.narod.ru/OBDII/Connectors1.jpg ).
Take a look the Basic codes by flashing "Check Engine-light" - http://www.alflash.narod.ru/Diagn/MILcode.pdf
HTH,
J2008: Beginning 2002, manufacturers shall make available at a fair and reasonable price,all 2002 and newer model year vehicle emission-related diagnosis and repair information provided to the manufacturer’s franchised dealers.Within 30 days of its availability to franchised dealers.
alflash is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Avalon/IS-350 engine codes osidepunker 1st Generation (1995-1999) 4 01-26-2006 01:33 AM
2001 Camry Check Engine light on: where to plug in the diagnostic tool camry-jc 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-19-2006 08:49 AM
