Tow a Lexus ES300 with automatic transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 07-09-2006, 09:34 PM   #1 (permalink)
View ipdc1's Photo Gallery
Hi,
I'm thinking of buying a 1993 Lexus ES300 to be towed behind my Class A motor home.
Before buying I want to make sure the ES300 can be towed with the 4 wheels down on the road
Seller says NO PROBLEM but I'm not sure and Lexus Canada is pretty vague
Car is a ES300 1993 with 4speed automatic transmission
Thanks
Chris
ipdc1 is offline   Reply With Quote
Old 07-10-2006, 03:48 PM   #2 (permalink)
View toyomoho's Photo Gallery
I can’t say about Lexus. I did just read mid 90’s auto Camry’s required an electric auxiary trans oil pump to keep the fluid circulating. I forget exactly where I got this info. It was a web search on towing cars. Someone wanted to drive their Camry in Neutral (engine on) and asked if that damaged the trans.
I read a lot of articles in Motor Home magazine about this subject. Some auto trans cars can be towed without a pump; some need to be restarted every xxx miles to circulate the oil, a few leave their cars engine running when towed. There are also kits to disconnect the axles.
Toyota may be vague on this for liability issues.
I would do some research; call a few places that sell the pumps (easy to install), motor home clubs, etc. There is a lot of data on the web with specific makes and models and if they can be towed safely as is. Get some definitive data. More then one person has had their trans damaged by improper towing.
My 85 Supra automatic transmission started slipping gears! ultraman69 Supra Forum 0 03-05-2006 04:36 AM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
A Sexier Lexus CDNVITZ General Discussion 16 03-31-2004 03:15 PM
