2000 Lexus CEL & Trac Light On - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 08-21-2006, 05:21 PM   #1 (permalink)
View phxnative's Photo Gallery
Question 2000 Lexus CEL & Trac Light On
Hi. The check engine light and the Trak light came on and the car runs rough with RPM's high. Took to AutoZone for code scan; results= 0440 which I was told is cylinder 5 misfire. I replaced the spark plugs, but the problem still exists. Can you advise? Thanks,
phxnative is offline   Reply With Quote
Old 08-27-2006, 12:29 AM   #2 (permalink)
View NYLexSC's Photo Gallery
Check your O2 sensors, they may be busted and could throw that code. Trac light comes on whenever the Check Engine light comes on, so that will go away when you clear the CEL.
NYLexSC is offline   Reply With Quote
Old 12-05-2007, 11:55 AM   #3 (permalink)
View kathienpb's Photo Gallery
Unhappy Same problem?
Hi there, I know these are old strings but we're having the same exact problem with our 2000 Lexus Es 300. The trac ctrl/check engine lite came on, the codes said noc sensors so we replaced those, then 02 sensors so we replaced those, then one of the 02 sensors again so we figured it was bad and replaced that last night as well. Didn't work, the lites came on again this morning. Is there anything else to try and get rid of the check engine lite? And the overdrive isn't working either. Please please help, we've tried everything, run scanner on transmission and nothing comes up there either. Can you please help me?
Thanks
Kathie
kathienpb is offline   Reply With Quote
Old 04-23-2008, 12:03 AM   #4 (permalink)
Dusty
View monstermechanic's Photo Gallery
engine miss fix
I have a car in my shop with the same problem, i cleaned the boots on the bottom of the coils, installed new plugs , and cleared the codes. car runs great
cleaned the boots with dish soap and a bottle brush.
monstermechanic is offline   Reply With Quote
Consumer Reports on HID Phi General Discussion 28 01-17-2007 09:23 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 04:51 PM
check engine light activated on my abused 2000 86mets Archived Corolla threads 14 04-25-2003 02:08 PM
