Extracting Codes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 10-04-2006, 08:14 PM   #1 (permalink)
View fe519's Photo Gallery
Extracting Codes
Hey everyone, I'm new to this Lexus portion of toyotanation. My friend is having some problem with his 92 es300 engine and transmission. I tried googling how to extract the cel codes but cant seem to find anything on how to do it. Can someone show me the way to get the cel codes and also the transmission codes? I really appreciate the help. Thanks again.
fe519 is offline   Reply With Quote
Old 10-04-2006, 10:30 PM   #2 (permalink)
View NYLexSC's Photo Gallery
Go to Autozone or Pep Boys and ask them to use their OBDI scanner to read you your codes, they should do it without any charge, or maybe a minimal fee.
Other than that, you'd need an OBDI scanner or you can count the number of flashes of the CEL light and each one has a corresponding set of codes that could be the possible issue, not as specific as a scanner though.
NYLexSC is offline   Reply With Quote
Old 10-05-2006, 03:10 AM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
I doubt they have OBD-I scanners. They're nothing but little shorting pins with a light on the end of them. The car has that from the factory LoL! The real Toyota TDLC1 / TDLC2 scanners that Toyota/Lexus have are about $6-7 grand a pop & even they don't scan so much as they log. They just trip TE1&E1 & count the pulses to read the codes like everything else. (Now they can do slow logging on the ES300's & LS/SC400's via the Vf2 data-port like an OBD-II car. It's just *extremely* limited & not worth the effort).
Short TE1 & E1 in either of the two diagnostics ports (DLC1 = Engine bay, passangers side, behind the wheel well, or DLC2 = tucked under the steering wheel off to the driver's side some)
When you turn the key to ON, it'll flash any stored codes. i.e. 1-3, 5-2, 6-9, (yeah!)
http://us.lexusownersclub.com/forums...=3725&hl=codes
http://us.lexusownersclub.com/forums...howtopic=26449
What are the problems you are having & what are the codes?
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-05-2006, 09:33 AM   #4 (permalink)
AutoZone by me has OBDI scanners...they've read my code on my 1994 Lexus when I had a CEL light (emissions related, bad charcoal canister).
Old 10-05-2006, 04:56 PM   #5 (permalink)
Hey NYLexSC, thanks for the reply. Thats what I was looking for and you were very helpful. I just have one last question, am I supposed to look for the flashes on the dash(CEL) or am I supposed to check the blinks with a test light on the port itself? My friend changed his tranny fluid about 2 weeks ago and the car took a dump a couple days ago. Before we go and buy a transmission, we just want to test the easy stuff like CEL or tranny codes... oh yeah, is there anyway to test the tranny codes? When the car is cold it seems to drive fine but after a minute or two warmed up, it barely moves and the car just revs. Do you think its the tranny?
Old 10-05-2006, 06:26 PM   #6 (permalink)
Toysrme's Avatar
Cool
When you bridge TE1 & E1, the CEL flashes any stored codes in numerical order. Just count the flashes.
Now with Turbo!
"Check engine light" error codes po446, po442, po440???? serabell xA Forum 10 04-12-2009 11:31 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-18-2006 12:06 AM
Reading codes White89SR5 Archived Corolla threads 3 03-12-2006 09:22 AM
