Blowing fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 10-19-2006, 07:38 PM   #1 (permalink)
rainman14624's Avatar
View rainman14624's Photo Gallery
Blowing fuse
Got a '96 ES300. Just had the top of the rear seat recovered. It's probably just coincidence, but after we picked the car up we noticed the power trunk release wouldn't work and then discovered the power door locks, dome light, ignition light wouldn't either. I figured it was a fuse. Replaced the dome fuse, but it blew the second time the doors were locked. Now it blows the fuse when the battery is hooked up. Any suggestions on where to look for the short - door lock actuator, maybe.
Any help would be appreciated.
Thanks in advance,
Rainman
rainman14624 is offline   Reply With Quote
Old 10-20-2006, 07:40 AM   #2 (permalink)
View clubfoot's Photo Gallery
Thanks in advance,
Rainman
If the dealer did the installation,...take it back to them for repair. I would remove the rear seat and check for damaged wiring.
clubfoot is offline   Reply With Quote
Old 10-21-2006, 02:07 AM   #3 (permalink)
View toyomoho's Photo Gallery
Sounds like a short in the wiring. If not under the seat, check the wires going between the drivers door and car frame. These can fray from opening and closing the door.
Old 10-21-2006, 10:17 AM   #4 (permalink)
Thanks for the suggestions. Located the short. It was in the vanity mirror light in the driver's side visor, which is worn out and won't stay locked against the ceiling. Any suggestions on where to find a replacement visor for my '96 ES300. Saw one for a '97 ES300 on eBay for $69 plus $12 shipping. Appears to be same visor. Any other suggestions?
Thanks,
Rainman
'99 Camry blowing the 'Gauge' Fuse Trajan Camry & Solara Lounge 9 Today 03:57 AM
1999 camry LE power windows, speedo, tach and temp guage fuse blowing edpop64 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-05-2006 11:19 PM
92 Tercel: blowing Fuel Pump Circuit fuse everyday solomonsterous Tercel, Paseo, Starlet, and Sera Forum 0 02-16-2006 01:23 PM
Fuse blowing DrewsCam General Discussion 2 08-08-2004 06:22 PM
