IS300 oem suspension clunking noise?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 01-18-2007, 11:41 PM   #1 (permalink)
View Hachi8x's Photo Gallery
Ok heres the deal. Slow speeds over speed hump i can hear an occassional clunk noise. My 2004 IS300 has stock suspension. I have taken to the dealer 3 times in the last year and they have replaced all the suspension components and still the same thing. Now they tell me they tested various other 2004 IS300 and they all have it..... i'm not quite sure if I should believe them. Anybody else hear this on a stock IS at slow speeds?
Hachi8x is offline   Reply With Quote
Old 01-19-2007, 02:32 PM   #2 (permalink)
View clubfoot's Photo Gallery
Did they replace the sway/roll bar end links?
clubfoot is offline   Reply With Quote
Old 01-20-2007, 03:30 PM   #3 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
have they replaced the strut mounts, as well as the bushings for the sway bars?
nodrogkam is offline   Reply With Quote
Old 01-21-2007, 03:26 PM   #4 (permalink)
solaraguy
anttarz's Avatar
View anttarz's Photo Gallery
def. sounds like your mounts and/or sway bar links.
2000 Camry LE
1999 Solara SLE V6 - Complete TRD Suspension (Struts, Springs, RSB, & FSTB) - OBX Headers, Random Tech w/ TRD Exhaust, 18x7.5 Kosei K1 TS
1995 Tercel Coupe -- 4-Speed, 15" BBS, ACT Clutch, CAI, Eibach Pro-Kit, FSTB, Custom Grill (sold 6/06)
anttarz is offline   Reply With Quote
Old 01-21-2007, 11:19 PM   #5 (permalink)
View NYLexSC's Photo Gallery
How many miles? If it's a lot, could be a wheel bearing also...
NYLexSC is offline   Reply With Quote
Old 01-22-2007, 05:26 PM   #6 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
My guess is the strut mounts or the sway/roll bar ends (take it to a local shop and have them use teflon tape on it). GL
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 01-26-2007, 11:14 PM   #7 (permalink)
Thanks for the feedback everybody. ya, they did replace the mounts 2 times. So, i'm certain its not that. I have 30k miles now, but that was happening way before. You all may be right about the sway bar links. I'll look into that and get some teflon...thanks!!
Old 02-07-2007, 08:17 AM   #8 (permalink)
toot toot ahhhh beep beep
View cuttooth's Photo Gallery
what kind of "clunk" is it?
alot of is300's have brake noise because of the floating caliper setup, mine included. i sometimes hear it when i'm going really slow and apply the brakes in situations like going over a speed bump or getting ready to make a turn.
if its something else, here's info from is300.net on other common noises
http://my.is/forums/showthread.php?t=285175
'02 is300, eShift, LSD
'94 toy pickup, 22re, 5spd, xtra cab
cuttooth is offline   Reply With Quote
Old 02-19-2007, 05:11 PM   #9 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
The other thing to remember - is you always notice noises while going at slow speeds more... I had times in my old camry when I thought something was going wrong with the suspension or engine, and I would realize I was driving on ridged concrete, or over numerous creases in the road
That is not to say you should never investigate problems - but if everything has been replaced, and there is on safety issue, I would just crank up the tunes a bit when going over speed bumps Did you ever end up checking out the endlinks? I know sway bars have a tendancy to be noisy if they are not lubed up around their bushings too... as people have already said
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 03-21-2007, 11:21 PM   #10 (permalink)
my.IS regular
View happysmp's Photo Gallery
If it's a squashing noise, it has to do with the sway bar bushings or the grease in them.
If it's a single clunk, it could be the sway bar hitting something when your suspension compresses (check the bar and area above for marks)
If you have SS lines, make sure that they are clamped down properly. Loose one's will clunk as you turn the wheel.
if not any of those, there's an all purpose suspension noise thread on www.my.is. look for it
HappySMP
happysmp is offline   Reply With Quote
05 RaV clunking noise yz125yamaha10 RAV4 Forum 12 08-07-2009 12:16 AM
1998 Toyota Tacoma Clunking noise front driver's side silverpigeon2 1st Generation (1995.5–2004) 2 12-31-2006 10:17 PM
Clunking noise 05Cam-Weasel Camry & Solara Lounge 5 03-13-2006 10:37 PM
ES300 Suspension noise shackner General Lexus Discussion 4 01-28-2005 01:00 AM
Clunking noise at right rear on a 94 Camry vio 3rd & 4th Generation (1992–1996 & 1997–2001) 3 02-06-2004 08:53 PM
