98 ES300 starts but can't keep idle and dies - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 03-26-2007, 10:07 AM   #1 (permalink)
View ftmail's Photo Gallery
Ocassionally, my car would not start up. The engine starts up but it does not hold the idle and and it dies immediattly. This happens 5 to 6 times a year, but when it happens it would not work even if I try 20 times. The car has about 90K miles and the check engine light is not on.
The only way to start it, is to press the left foot on break and in the same time lightly push the gas with the right foot... it is crazy, but this is the only way to keep the engine at about 800-1000 RPM. Then, I can put the car in gear, release the break, and the the car starts moving. After the car reaches about 20-30 mi/h, I don't have to keep the idle (with the right foot) and I can drive normally. If I stop the car within 1-2 minutes, the car has the same problem. However, if I run the car over 30-40 mi/h and it gets to shift to higher gears, the car works normal and even if I start it, it will re-start normally.
ftmail is offline   Reply With Quote
Old 01-24-2008, 09:27 AM   #2 (permalink)
View jeremey3270's Photo Gallery
I have the same problem whats the fix?
jeremey3270 is offline   Reply With Quote
Old 01-24-2008, 12:40 PM   #3 (permalink)
View toyomoho's Photo Gallery
If the car starts but dies it might be the air control valve, this valve controls low idle speed. Do a TN history search as issues with the valve and cleaning methods to solve them have been covered before. Might also be the throttle position sensor.
Old 01-24-2008, 05:02 PM   #4 (permalink)
The iac needed to be cleaned
If you do a search for one of my thread ( 98 V6 starts but can't keep idle and dies ) you will find the details explanation of what I did.
The iac and TB needed to be cleaned and my car is running properly ever since I cleaned it
Old 01-30-2008, 01:36 AM   #5 (permalink)
A Lone Wolf
View wed3k's Photo Gallery
nice, my dad's es300 is having this problem too. thanks
94 pickup 4x4 5vzfe swap
99 subaru forester
90 vw corrado BRC
90 vw corrado nugget yellow
wed3k is offline   Reply With Quote
Old 01-31-2008, 09:18 PM   #6 (permalink)
n00b Squad
View NeatSC's Photo Gallery
Check your air flow meter too, it may be dirty or the connector could be damaged.
NeatSC is offline   Reply With Quote
Floor it at idle and engine bogs down and dies 94celica94 Celica Forum 13 05-23-2008 10:48 AM
Car dies at idle Ryncub Supra Forum 8 01-10-2006 10:30 AM
02 Highlander dies (idles really low) on cold starts... llkojakll 1st Generation (2001–2007) 3 09-01-2005 05:49 AM
