99 ES300 throwing code P1354 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 03-28-2007, 06:12 PM   #1 (permalink)
View rasta420's Photo Gallery
I'm dealing with a friend's 99 ES300 which is throwing code P1354 and misfire codes for Cylinders 2, 4, and 6, all on Bank 2. When the car is cold, the car idles fine, but once the car is warm, the idle surges all the way to 1400-1500 rpm and stays there. The engine runs rough and misfire is very apparent.
I'm trying to see if anyone else had this problem, or where I should start probing for problems. Anything would help.
Thanks.
rasta420 is offline   Reply With Quote
Old 07-31-2007, 03:27 AM   #2 (permalink)
View chester08's Photo Gallery
Code P1354 for lexus is a VVT System Malfunction (Bank 2) for Lexus... And this fault codes only display the apparent fault that the engine management is seeing. But this can be caused by a number of things in reality.
Personally i'd go for either f the Lexus auto parts such as Cat failure, or the MAF sensor can sometimes give faults like this. Generally, a fault code won't point to all four lambda sensors, they tend to at least narrow it down to a bank. But, really this should be looked at by a Toyota garage - and i mean one that knows what they are doing! Good luck!!!
chester08 is offline   Reply With Quote
Old 07-31-2007, 12:11 PM   #3 (permalink)
View toyomoho's Photo Gallery
The VVT-I oil control valve may have a problem. Remove the timing cover to see it, attached to cylinder head.
disabled EGR, now throwing code dchriste Camry & Solara Lounge 9 04-23-2006 03:14 AM
'99 Camry, I4. P1130 code sprung up: "A/F Sensor.... ". Any suggestions? genEus Camry & Solara Lounge 3 07-19-2005 07:13 AM
anyone know the engine code of a 97ish es300??? wontonjohnny Hardcore Tech and Competition 5 05-07-2005 05:29 AM
OBD II P1121 Code '99 Land Cruiser bigdz Land Cruiser Forum 1 03-11-2005 06:37 PM
99 ES300 Trac Off and Check Engine dank General Lexus Discussion 4 01-18-2004 03:28 AM
