How important to fix oil leaks?
I have a 15 year old Windom with a slight leak from the front and rear valve cover gaskets. I don't seen any oil on the ground and the dip stick level don't seem to drop much over the past 3 weeks.
Do such oil leaks have a tendency to get very bad suddenly spraying oil all over or do they get worse gradually? I'm a little tight finance-wise and am thinking of delaying until I see oil on the ground or oil level drops at a higher rate. I heard that using thicker oil would slow down oil leaks, so I'm using Mobil Super Semi-synthetic 15W40.
