'98 ES 300 o2 sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 05-16-2007, 09:37 PM   #1 (permalink)
View JohnHealy's Photo Gallery
Hi I have a 1998 ES300 which has the check engine light on. I ran the code and it tells me that I need to replace the o2 sensor. Being in NY I purchased the o2 sensor not for California cars. jWhen I tried to plug it in the the plug did not fit. I brought it back and the parts guy told me I must have a California car. The new sensor is twice as much. Also ther are two sensors. one before the cat and one after. All total the two ate about $460.00
This sounds a bit extreme. Also, If anyone knows how do you unplug the rear o2 sensor? Does it disconnect through the arm rest? Any help would be greatly ap-preciated.
Thanks in advance.
John
JohnHealy is offline   Reply With Quote
Old 06-05-2007, 10:15 PM   #2 (permalink)
kauz's Avatar
View kauz's Photo Gallery
John, If you still need help on this, let me know. I've already replaced both O2 sensors on our 97 ES300 and can give you some suggestions.
kauz is offline   Reply With Quote
Old 07-01-2007, 05:17 PM   #3 (permalink)
ES300
View plm908's Photo Gallery
O2 Sensor 460
Go to Toyota Parts Dept. instead and buy your o2 Sensor, you'll be fine. They cost is considerably lower. Also, I will be parting out my car soon, I'm going to post in the classified section and if I can part out my car, I will. You can PM me. I have a2001 though, I don't know if they're the same, you'd have to find out.
plm908 is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
List of V6 5-Speed Camry's I found currently for sale ASG14 Camry & Solara Lounge 13 10-22-2006 05:59 AM
O2 Sensor trouble victor91mr2 MR2 Forum 0 03-26-2005 05:09 PM
