A p1780 is a code for the neutral safety switch that is mounted on the tansmission. This switch basically tells the engine control computer what gear you have the car in. The code sets when it recieves conflicting signals from the switch, such as being in park and reverse at the same time. The switch or the wiring could be the problem. Its more likely the switch but its best to have it checked first. The switch runs anywhere from $150 to $250 depending on which type it is.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
