Snow and electronics... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 01-11-2008, 06:44 PM   #1 (permalink)
View mitz's Photo Gallery
Hi toyotanation!
Car: 2002 ES300 loaded
story:
-So I just came back from the snowy mountains (25-30 degrees; not too cold).
-Upon first hitting snow w/ chains, my "brake," "VSC," "Trac off," and "check engine" lights all came on.
-the next morning, my speedometer read "0" at all speeds and my odometer is non-funtional (stuck at 74,913).
-Temperature gauge is stuck at 38 degrees (its 65 outside today).
-GPS is VERY squirly (it moves while im parked and became highly inaccurate) and I have a feeling all these problems are interrelated and it could just need an ECU flash or reset. H
-Car now dies at idle
HELP lexus GURUS!
I want my car back!
mitz is offline   Reply With Quote
Old 01-12-2008, 12:19 AM   #2 (permalink)
View clubfoot's Photo Gallery
Not sure what is causing your problems, but disconnect the battery overnight, negative terminal then positive terminal in that sequence.
clubfoot is offline   Reply With Quote
Old 01-12-2008, 05:50 PM   #3 (permalink)
I tried that. now the car dies at idle
i did an obd2 scan PO500 which is Vehicle speed sensor malfuntion. I'm thinking it could be a bad ground on the ECU. someone had similar problems (no speedometer and no odometer) on a mercury tracer and hardwiring the ground pin on the ECU solved his problem. mine could be similar. I'll keep troubleshooting.
Old 01-17-2008, 02:13 PM   #4 (permalink)
Thanks to the 1 person who responded.
I fixed it today, cost me $300 with a fellow electrician. he said both speed tire sensors were replaced on the front. everything is back to normal.
