Camshaft Timing Marks - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 03-24-2008, 12:53 PM   #1 (permalink)
View POSES250's Photo Gallery
Can anyone shed some light on the RH head camshaft instl.. Book says to install with the double dots lined up together, but if I do this, the camshaft pulley marks are off. Has anyone done this? HELP
POSES250 is offline   Reply With Quote
Old 03-31-2008, 12:45 AM   #2 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Did you ratchet back the gear on the camshaft?
One of the camshafts have a split gear in it. If you failed to thread a 10mm bolt on that gear before you took it out, it will ratchet out w/out you knowing it.
Just turn the gear couterclockwise and thread in a 10mm bolt to lock it in place and re-install the camshaft.
Don't forget to take out the 10mm bolt before you rotate the shaft or else it will chew up the head.
Goodluck.
Nad1370 is offline   Reply With Quote
