99 ES300 Trac Off and Check Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 11-29-2003, 12:19 PM   #1 (permalink)
View dank's Photo Gallery
Any idea what's up with this? Check engine light and Trac Off are both illuminated. What could that mean? I double checked the Traction Control switch and its set to on. What gives?
dank is offline   Reply With Quote
Old 12-02-2003, 04:37 PM   #2 (permalink)
V8 POWERRRR
View skperformance's Photo Gallery
you have a problem that needs a obd2 scanner to solve
R.I.P. Dad, Shabeer Khan 11/09/06
Toronto area Lexus Owners Meet My 98 LS My 94 ES
skperformance is offline   Reply With Quote
Old 01-14-2004, 12:29 PM   #3 (permalink)
View AirGuardian's Photo Gallery
Had the same problem. Went to the dealer to get the diagnostic computer check out. Turns out it was one of the 4 O2 sensors indicating a leaner than normal mixture was occuring! Dealer is replacing one of the rear sensors - it was malfunctioning and the engine is running fine regardless of the failed indicator. If it bugs you, you can disconnect the battery temporarily to see if it comes back - than go get it checked out to verify this info! You only lose traction control - My light came on every few hundred miles - heavy accelerating moments mostly!
AirGuardian is offline   Reply With Quote
Old 01-14-2004, 03:33 PM   #4 (permalink)
V8 POWERRRR
the trac light comes on whenever the Cel is on also
there are also only 3 o2 sensors in any 1mz-fe engine
2 before on each manifold and one after the cat
Old 01-18-2004, 03:28 AM   #5 (permalink)
View alflash's Photo Gallery
Hello,
Dear dank,
I think about System (TRC) on Yours Vehicle provide procedure for retrieving trouble codes without a scan tool (by short terminals Tc and E1 in DLC No.3 or DLC No.2).
Need read the throuble codes and check faulty "devices".
Best Regards,
alflash is offline   Reply With Quote
