1UZ not willing to start - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 02-28-2011, 10:52 PM   #1 (permalink)
View jkomets's Photo Gallery
I'm looking at buying an SC400 that is having starting problems. It turns over and I know it's getting fuel because I can smell the unburned fuel vapors coming out the tailpipe. I doubt compression is the issue since the owner says one day it suddenly stopped (after it got quite cold). That leaves spark, which is supported by the way in which it tries to start, firing erratically but never staying running, even at WOT while cranking. I know timing isn't manually adjustable on these engines.
It seems unlikely that it's a coil, wire, or plug issue as that would cause rhythmic firing rather than erratic. I'm only left with two options, a bad cam sensor/wiring or something distributor-related. Am I correct? I was thinking of going back there tomorrow with a timing light and checking the timing, but I wouldn't be sure what to do if it were off a few degrees.
Thanks for any insight.
jkomets is offline   Reply With Quote
