97 ES300 (Windom) Beep Sound When Reversing - How To Stop It - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 09-18-2004, 11:29 PM   #1 (permalink)
View ffcheung's Photo Gallery
When I put the shift stick of my 97 ES300 (Windom) to the Reverse ("R") position, an intermittent and rather loud "beep-beep..." sound is heard. I found this beep sound annoying. How can I disable this sound?
ffcheung is offline   Reply With Quote
Old 09-19-2004, 07:14 PM   #2 (permalink)
View joshthorsc's Photo Gallery
Does it sound like one of those truck backing up beeping sounds? If it does sound like it, I'm not sure if the es300's acme w/ a beeping sound thingy but they do sell those beepers at stores and if your not the first owner, then the previous owner may have installed that in.
1992 SC300 5-Spd(NA-T)
1991 MR2 Turbo
2004 Tundra Limited Access Cab 4x4
1985 Toyota MR2(DD)
joshthorsc is offline   Reply With Quote
Old 09-20-2004, 10:18 AM   #3 (permalink)
Yes, it does sound like those truck backing up beeping sound. The sound comes from the front and inside of the car. I tried to locate the beeper but could not found it. I bought the car second hand so am not the first owner.
Old 09-20-2004, 10:43 AM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
it is an aftermarket warning beeper.....try looking at ur battery terminals...its gonna need a source of power somehow and the unit may be wired to the battery....track the source of the unit from there perhaps.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 09-21-2004, 11:21 PM   #5 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
It's going to be wired to the reverse lights. Many of those replace one of the reverse light bulbs. Pull them out and check.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 09-22-2004, 07:12 AM   #6 (permalink)
Thanks for all your advice.
The beep sound appears to come from inside of the car and from the front. It seems the beep is meant to alert the driver that the car is in reverse gear.
I tried putting it to reverse gear and went out of the car, the beep was very weak when heard from the outside.
Old 10-03-2004, 03:43 PM   #7 (permalink)
View kenratboy's Photo Gallery
Must have been a old persons car
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline   Reply With Quote
Old 10-04-2004, 02:05 AM   #8 (permalink)
You are right! I was told that the car belonged to an old man befoer I bought it I don't need to reverse beep warning yet
