hubcentric rings - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 12-21-2004, 11:24 AM   #1 (permalink)
View ricky's Photo Gallery
hubcentric rings
Assist me in locating the correct hubcentric
rings for my vehicle. I own a 1996 Toyota Camry and I
purchased a set of 17in Lexus IS300 rims. I balanced
the wheels numerous times and rotate all tires. I get
a constant vibration on the steering wheel. With the
stock 14in rims no problem. I kind of had it and
thelexus rims, they have been on the shed for the past
year and a half. I was under the impression that since
they were toyota that would not be a problem but it
was.
There are different sizes and I do not know what to
choose
Ricky
ricky is offline   Reply With Quote
Old 01-02-2005, 07:43 PM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $703465
iTrader Score: 6 reviews
View EKam's Photo Gallery
Hubcentric rings are only for aftermarket wheels, the IS300 wheels are already hubcentric to Toyota hubs.
Check your tire and see if there are any improper wear. You should get an alignment aswell.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 01-02-2005, 10:52 PM   #3 (permalink)
View bosco659's Photo Gallery
Canada
Take the car with the Lexus rims to a reputable tire shop. If balance is perfect there's a possibility of a bent rim. If you switch the tires from front to back, is the vibration still there?
If not you may be able to isolate the problem to one tire / rim combo.
HTH
2000 Supercharged 4Runner
'89 Supra Turbo with a "few" mods
bosco659 is offline   Reply With Quote
Old 09-23-2006, 07:09 PM   #4 (permalink)
View braun's Photo Gallery
HTH
I concur. if it vibes on the steering wheel, one of the front wheels/tires are suspect..
braun is offline   Reply With Quote
Old 09-23-2006, 09:07 PM   #5 (permalink)
View NYLexSC's Photo Gallery
Yeah, vibrations through the steering wheel are usually front tires or front end.
Vibrations through the seat generally indicate problems with the rear wheels or rear differential/axles.
NYLexSC is offline   Reply With Quote
