radiator bleed procedure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 01-07-2005, 12:00 PM   #1 (permalink)
View BobES300's Photo Gallery
Does anyone have the procedure for an ES ? I drained my coolant and now have a sloshing noise in the dash and very little heat. Must be an airlock in or around the heater core.
thanks,
Bob
BobES300 is offline   Reply With Quote
Old 03-14-2005, 07:04 PM   #2 (permalink)
View steve97's Photo Gallery
sounds like an air lock. Got to force the fluid around to get the air bubbles to end up at the top of the radiator. With heater temp on high, turn on car and once engine is hot start massaging the top radiator hose to force the water to move around inside(and the air bubbles). Things are getting pretty hot, might want to use a glove for this.
Then wait for car to cool down. Check coolant overfill jug, probably empty now. Open radiator cap CAREFULLY, then add coolant/water mix. Tighten cap and fill overfill jug to full line.
should be good to go after that.
steve97 is offline   Reply With Quote
Old 03-15-2005, 10:41 AM   #3 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
first off, what did you fill it with? i always let it run on just distilled water for a city drive...for a day to ensure full flush..then i fill with 70 water and 30 coolant (since i'm in houston and our winters are not that cold). Again, make sure the levels are filled well....i've never had an airpocket with my ES, on my solara everytime...
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
