Plug Replacment - ES250
I'm trying to change the spark plugs - and wires - on my '90 ES250. Cylinders 2, 4, 6, and 5 I have changed both plugs and wires already. (Engine is the 2VZ-FE, plugs 2,4,6 are in front, 5 is nearest distributor.) I can't seem to get to the others without major surgery.
Is there a trick to getting at the no. 1 and 3? I see that the intake may have to be removed but I was hoping that here was a trick or tip to get a hand back there. I know on some older GM vehicles, I had to either rotate the engine (tranny in neutral, remove front motor mounts and rotate forward then hold with second hole in motor mount strut.) or actually lift the engine block.
Has anybody gotten to the number 1 and 3 spark plugs without removing the intake??
Thanks!!
OKBill
90 ES250
