SC400 auto to 1JZGTE 5sp Conversion, HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 04-05-2005, 01:24 PM   #1 (permalink)
View soarer's Photo Gallery
I'm looking to convert my 1992 sc400 to a 1jzgte 5sp. I've been looking around and have come to find that 5sp soarer clips are REALLY rare. The supra 1jz 5sp clips are a dime a dozen though. Has anyone ever swapped in a 1jz from a supra? If so, what additional parts do you need? Any input would be appreciated.
Cheers...
soarer is offline   Reply With Quote
Old 04-07-2005, 07:56 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
the same parts youd need in any otehr conversion.. if you REALLY want to do this.. youd hav ethe gearbox already, and then youll find out what you need after... expect car to be off hte road for a month or 2 if youre doing it yourself
terrastrife is offline   Reply With Quote
Old 04-07-2005, 12:05 PM   #3 (permalink)
The question is, can I use the supra:
Clutch pedal and slave cylinder, brake pedal, wiring harness, crossmember, motor mounts, driveshaft etc.....???
