Be sure you put a timing light on it.
Good work!
Clean his entire upper intake.
That thing, including the ACIS flap hanging from the side (That's his varriable intake).
After 9 months without cleaning they cake up so bad you loose 5 hp. (in turn lowering economy)
If you are really a good grandfather!!!
The ECU grounds the (red/orange/brown) ACIS vacuum switching valve (VSV) so that it opens. This allows vacuum to come from the vacuum tank, up through the VSV, to the ACIS's vacuum actuator. The ECU opens it when : The car is moving/under load (not parked), 3900rpm +, Throttle Position Sensor (TPS) is 50% open or above. That is too late for power. (notice the boost at 4000rpm)
The vacuum tank (it's under the battery). Pull the vacuum hose off that runs between it and the bown VSV. Connect it on the ACIS's actuator, and then put it to one of the three vacuum nipples on the top of the throttlebody. (Let it share with one of the EGR controls. Those are the two nipples facing the passanger side)
Either disconnect the EGR (raising emessions, but forever fixing the massive carbon buildup problem) or take a T fitting (10 cent aquarium fitting works just fine!) and T it into that.
This way it's close idling, but about the time you can pop the throttle plate open, it opens! (even idling)
Now the vacuum tank is un-used, and you can cap it's sorce (a screw in the vacuum line works) and the vacuum tank may be disgarded (saving a few lbs of weight)
