SC 300 TT ?'s - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 04-28-2005, 12:35 AM   #1 (permalink)
turbo lexus pile
eblick99's Avatar
View eblick99's Photo Gallery
Question SC 300 TT ?'s
I have a '92 SC 300, which I want to turbo. I dont want to turbo the existing 2JZ-GE, as I have both a 1JZ-GTE and a 2JZ-GTE in my shop, and want to know what is the easiest route to go. Obviosuly swapping motors is the first idea, but I was told with the 2JZ-GTE (which is what I would prefer to use) the motor mounts, some accessories, and and dash electronics do not integrate properly with the GTE ecu, as well as the transmission/driveline. One possible way around this is by removing the head of the the GE and swapping the head for the GTE, switching out ecu/wiring harness (this route would solve tranny, motor mount and accessory issues, but not electronics). Also once removed, new rods and pistons would need to be put in the GE block. Is this worth the effort? also what are some ways around the wiring issues? stand alone, re-wire and a dash swap are what I've goten so far. Anyways looking for all the ways to go about this, so any ideas/suggestions or advice, preferably from experience, are greatly appreciated. thanks!
eblick99 is offline   Reply With Quote
Old 04-28-2005, 05:48 AM   #2 (permalink)
gLok's Avatar
View gLok's Photo Gallery
The rods and crank in the GE block are the same as the GTE, the pistons are different however and have a higher compression ratio. It really depends how much power you are looking to make. If your horsepower goals are mild, you can get away with a headgasket to lower compression as far as engine modification go. The weak link after that will be your transmission.
I would suggest going and checking out Supraforums.com. They have a ton of information about turbocharging the GE block. There is a guy running 9 second quarter miles with a stock bottom end 2JZ-GE.
gLok is offline   Reply With Quote
Old 05-06-2005, 01:02 PM   #3 (permalink)
View wrenchtech's Photo Gallery
What did they do for Japanese market models? Did they ever run a 2JZ-GTE in the SC300 over there? It seems they did in the GS300/Aristo. I'm a sedan-man so I'm looking at the possibilities for the first gen GS. I found a Altezza 2JZ-GTE front clip for sale, auto tranny, wiring and ecu included for $2500. I live outside of the emissions inspection region so I'm thinking I may just run it JDM spec in my U.S spec. car.
wrenchtech is offline   Reply With Quote
Old 05-09-2005, 09:21 PM   #4 (permalink)
Benz Tech
View got_trd's Photo Gallery
the GE head is better than the GTE head so why would you want to do that?
1JZ all the way. Me and 2 other guys pulled it off in a weekend with rain for like 6 hours on one of the days...
-ChiNo-
93' SC300 (the red one in pic)
:1JZ-GTE: :Blitz: :HKS: :B&M: :Apex-i: :Cusco: :Autometer: :Bilstien: :Optima: :Autobanh: :Unorthodox Racing:
got_trd is offline   Reply With Quote
