newbie,urgent help! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 05-05-2005, 10:42 AM   #1 (permalink)
View bm1139's Photo Gallery
Gen1 newbie,urgent help!
hello guys,am new here.have got this quirky problem with my 91 ls400 and needs some updates frm anyone.everytime i step on the gas,there is not downshifting of the gears and the engine becomes jerky until it speeds up.i suspect some blockages in the fuel or air line.as i m a diy guy,i have clean the throttle body and changed the fuel filter but to no avail.can anybody help me put here back to her former glory!thanks.
bm1139 is offline   Reply With Quote
Old 05-05-2005, 01:34 PM   #2 (permalink)
Toyota Lexus Scion Guru
View Flipside909 [SC³]'s Photo Gallery
When was the last time you changed the tranny fluid?
ClubLexus Editor/Events Coordinator
GRS191
Flipside909 [SC³] is offline   Reply With Quote
Old 05-06-2005, 10:48 AM   #3 (permalink)
have changed them about 1month back but have only clock about 800km.do they affect as in my case.am really lost and cracking my head trying to trobleshoot.
Old 05-06-2005, 05:39 PM   #4 (permalink)
You might want to post your questions on our site here:
http://www.clublexus.com/forums/forumdisplay.php?f=10
There might be some folks that have experienced the same symptoms on their own LS.
GRS191
Old 05-22-2005, 09:46 AM   #5 (permalink)
thanks guys,guess i will have to wait a little longer for my babe to regain former glory!
Old 06-11-2005, 05:21 PM   #6 (permalink)
View rbalan's Photo Gallery
I think you should try changing spark plugs and high tension Cables full set. I had a similar problem and changing them rectified it.
rbalan is offline   Reply With Quote
Old 07-18-2005, 12:44 AM   #7 (permalink)
View lexusmech's Photo Gallery
Try putting it in first gear via the shifter. If this works, it will tell you the transmission is shifting internally.
What transmission fluid did you use? Did you use Mercon? Dextron? That car needs T-4 (toyota ATF not sure if it's at kragen or not).
lexusmech is offline   Reply With Quote
Old 08-18-2005, 01:12 AM   #8 (permalink)
have tried downshifting on the go to 2.no problem except it will jerk if rpm is to high.could it be the throttle controller?
