What controls the radiator fans?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 06-15-2005, 07:49 PM   #1 (permalink)
View KS_Hicks's Photo Gallery
USA What controls the radiator fans??
Hi, I'm new to Toyota Nation. I don't really know if this is a problem, but I want to ask anyway. I have a 1990 Lexus ES250 and my dual fans don't turn on when they are supposed to. What I mean is when I turn the key to ACC or to START both of my fans automatically come on. I know one is supposed to come on when the air conditioning is on and the other is supposed to turn on when the engine is a certain temp. They both come on at the same time whether hot or cold and they stay running until the car is turned off. I don't know if I have a problem, but I really don't want to burn out the motors on these fans. Could it be a relay, temp. switch, coolant temp. sensor or what?? Please help!!!!!!! Thanks!!
KS_Hicks is offline   Reply With Quote
Old 06-17-2005, 12:19 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
on my car (camry) the fans come on when the engine is warm, and when the air is on, your problems may be hydralicially (sp) related... take it to a radiator place or dealership and have them troubleshoot
BlueFusion6851 is offline   Reply With Quote
Old 06-26-2005, 12:21 AM   #3 (permalink)
I don't even know where to start looking. Please help!!
Old 06-26-2005, 01:44 AM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Take it to a shop that knows what they are doing. That's an expensive high tech car you have and easy to create VERY costly repairs.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-28-2005, 12:37 PM   #5 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
I think older ES models had fans coming on when on accessory mode! (i've asked this on clublexus as well, and no one replied to my q)
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 06-29-2005, 10:37 PM   #6 (permalink)
So when the car is on or running, the fans are naturally going to run all the time?? Both fans even though the a/c is off?? This isn't like other vehicles whose fans come on when the temperature is right or if the a/c is running. So I might not have a problem at all??
Old 06-29-2005, 11:01 PM   #7 (permalink)
Moving Forward
View Cyorke's Photo Gallery
It could be any number of things from realys to coolant temp sensor, to ac switches. Typically the fans will only come on when the car is at a designated temp or like you said when the a/c is turned on. Sounds like you need to have it checked out. I shouldnt be a hydraulic problem because the car has to be running for the P/S pump to run the fan like it does on a Gen 3 camry.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 06-30-2005, 11:53 AM   #8 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
I went thru the same questions, and all relays, thermostar, waterpump, everything checked out fine. I didn't get a clear answer, i've since added close to 50K miles since i first asked that question two years ago!
Old 07-02-2005, 02:14 AM   #9 (permalink)
Well the thing is, is that I have in the Air Force and I am moving to Germany and I am shipping the car in about 3 days. If its not a problem then cool, but I do not want to burn out the motors on those fans cause I know they don't come cheap. By the way, how many coolant temp switches are there on this model and year??
Old 07-16-2005, 08:24 PM   #10 (permalink)
View mars7's Photo Gallery
I just purchased a 1998 ES300 recently and have a similar issue. When the car is started up and idling neither fan runs. If I turn on the AC then both fans run. I let the engine idle for a while to warm it up and neither fan runs. Is this normal or is there a problem? If it is normal what triggers the fans to run without the AC running?
mars7 is offline   Reply With Quote
Old 07-18-2005, 01:00 AM   #11 (permalink)
View lexusmech's Photo Gallery
You might have a stuck relay. I don't know for sure on the ES250 (I have one) but on my Mazda, if you lose ground on a sensor, the fans come on automaticly as a default mode. Since the A/C fan is on too, maybe the switch for the A/C is stuck and/or lost ground. Would have to look at the schematics.
lexusmech is offline   Reply With Quote
