Bad Luck 92 Es300 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 06-16-2005, 03:00 PM   #1 (permalink)
View desperate's Photo Gallery
Bad Luck 92 Es300
Today while driving less than 1 mile from my home my car started dragging then once i pulled over and out the car in park. When i tried putting the car in drive, reverse, and neutral it wouldn't change gears. I had it towed and when the guy when to put it in neutral all the gears worked, he was able to drive it right into my parking stall. I was told it may be my transmission? I didn't have any warning signs, do these things just go out? Or maybe there was and I just don't know what they are. I have had this car for 4 months. I already got everything pertaining to the over heating system repalced, knock sensor, transmission flushed, head gasket replaced and some other gaskets, should i just sell this car or what?
desperate is offline   Reply With Quote
Old 06-16-2005, 04:40 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
what is the mileage on the car??.....how was it driving prior.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 06-16-2005, 05:53 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
I'm thinking the neutral safety switch is worn out.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-20-2005, 04:43 PM   #4 (permalink)
It Was Running Fine. I Got A Motor Mount Changed About 3 Weeks Prior. The Driving Was Fine. I Noticed A Little Pull, But Not As Much Since I Got One Of The Motor Mounts Replaced. It Never Stalled On Me Or Anything.
Old 06-20-2005, 04:45 PM   #5 (permalink)
What Should I Have The Mechanic Check On The Car That Can Keep The Car From Shifiting Gears?
Old 06-23-2005, 12:33 AM   #6 (permalink)
Woogee's Avatar
View Woogee's Photo Gallery
It Sounds Like Toysrme Is Correct With His Guess. Regardless You Should Try To Take It To A Trusted Mechanic. Why Are You Typing Like This, By The Way?
Woogee is offline   Reply With Quote
Old 06-24-2005, 01:17 PM   #7 (permalink)
I had the car checked the mileage is about 164,000. They had to rebuild the transmission
