Lexus SC430 cd changer problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Lexus Forum > General Lexus Discussion
General Lexus Discussion Forum for all Lexus models: ES, IS, GS, SC, LS, RX, GX & LX.
Old 07-11-2005, 04:32 PM   #1 (permalink)
View strmagiceet's Photo Gallery
One of my cds got stuck and is jammed in the cd player of a sc430, does anyone know how to ttake it out? i would take it to the dealer, but im afraid they might charge me. Anyone know where i can get instructions on how to take apart the dash, such as a free manual?
Any help would be appriciated.
thanks
-=TOTALED=- Need money for a new car...
1994 Camry XLE V6 3.0L - somewhat modified.
strmagiceet is offline   Reply With Quote
Old 07-18-2005, 01:16 AM   #2 (permalink)
View lexusmech's Photo Gallery
First, do not use cd's with exterior labels. Ok yeah you're right as far as charging you. IMO they should warranty it (assuming you're under warranty). I do not recommend you take the changer apart itself. I work at Lexus and we send them back to the factory and they mail the cd's to you.
As far as I know there is no info on what cd's or not to use in the changer. On that note, if they didn't provide you with info saying don't use labeled cd's, then it's under warranty for sure. I have fished out some cd's with tweezers or very slim needle nose plies.
For the most part, they shouldn't charge you or they have sucky customer service.
lexusmech is offline   Reply With Quote
Old 08-05-2005, 08:14 PM   #3 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
CD Changer
The trick to it is to use two business cards to pull it out. Our dealership (Southfield, Mi) wouldn't charge you unless it is impossible to get out. Otherwise, we would order a replacement head unit which may or may not be covered under warranty (depending on the situation).
Hope this helps.
troy is offline   Reply With Quote
Old 02-09-2006, 06:17 PM   #4 (permalink)
View 430texas's Photo Gallery
I have the same problem. Used a CD with a label and now it is stuck. I cannot open the door to get access to the stuck CD. If I press load it just kicks over to the Radio and the door does not open. Eject and Play do not work either. I have 6 CDs in the in-dash changer but it only shows that 4 are loaded.
Please help.
430texas is offline   Reply With Quote
Old 02-10-2006, 10:48 PM   #5 (permalink)
Basicly you need to have the factory replace the unit and send you back your cd's. If you can actually manage to get the door open you may be able to use some needle nose pliers that I actually got from Sears. They're very very thin/long needle nose. They work very well, tweezers may not work. Otherwise head to the dealer.
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
