It is located inside the HVAC. There is a removeable cover on the bottom held in place by 2 wing nuts. Remove this door and both (2) can be removed - these lay side by side
Everything is located behind the glove box...somewhere.
Here is the instructions in Alldata ( minus the pictures)
Remove No.2 under cover
(a) Remove two wing nuts and lower cover from cooling and blower unit.
(b) Pull the rear air filter downward
(c) Before the filter touches the floor carpet, bend the filter upward as shown in the illustration.
d) Slide the front filter toward the rear and remove it the same way as the rear filter.
Install by following the removal procedure in reverse order.
Sorry...even if you looked at these pictures...I think your main trouble will be getting to the HVAC system.
Good Luck!
Digger08
Digger08
Lexus IS300
01' Onyx/ Arm Rest/ 02 Tails/ Xpel/ Carson Tuned/ Eibach/ Ltuned 18's/ Injen Intake
GReddy EVO/ TeCk grounding kit/FigProprod/DashTray/ LSD/Ltuned Sways
