You are not crazy, but using antifreeze is some bad information!
You have a COOLING FAN with HYDRAULIC MOTOR not only does this have an oil system with inlet piping, but a COOLING FAN RESERVOIR TANK which sounds like what you are describing.
I just checked my Alldata, I can only find one refrence and it does in fact (seperately) state during the cooling fan assembly procedure to:
1. to top up the cooling system with antifreeze,
2. and then top up the fan motor with "cooling fan fluid"
Looks like it may be connected to the Power steering oil cooler as there is a seperate cooling fan oil cooler as well. My best guess says it uses power steering fluid as it is connected to the PS system.
Excerpt from alldata:
"DISCONNECT POWER STEERING (PS) OIL COOLER FROM COOLING FAN OIL COOLER Remove the 2 bolts, and disconnect the PS oil cooler from the cooling fan oil cooler."
Do not put coolant in this! Go to the dealer and ask for "cooling fan fluid", see what oil is recommended for this system.
I'm sure someone can confirm this for you, that is familiar with this engine.
Thats all I got.
Digger08"
Digger08
Lexus IS300
01' Onyx/ Arm Rest/ 02 Tails/ Xpel/ Carson Tuned/ Eibach/ Ltuned 18's/ Injen Intake
GReddy EVO/ TeCk grounding kit/FigProprod/DashTray/ LSD/Ltuned Sways
