Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - '99 Tacoma starting problems
View Single Post
Old 10-17-2003, 09:28 AM   #2 (permalink)
Ross_G
View Ross_G's Photo Gallery
starter
Check your connections at the starter often you may find a bad or corroded starter solinoid wire. If that is not the problem try replacing the starter with 1 from napa . Get the brand with the lifetime warranty and you will only pay for it ounce even if it does go bad again . Just make sure to hold on to the receipt. good luck
Ross_G is offline   Reply With Quote
