I'm starting to love NY, I dont even get my emissions tested.
It's more like yep, there's an exhaust; pass
From what I read, your problem is most likely, faulty cat, clogged egr, timing, spark plugs, a malfunction of the cooling system causing high combustion temps. All of the above could be causing high temps which create NO, except a faulty cat, being that doesnt have much to do with temps.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
