Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - ABS chatter and low pedal
View Single Post
Old 01-02-2008, 04:10 PM   #4 (permalink)
dc_98_cam
The Gen 3 Brake section of the repair manuals says to do this first:
When the ignition switch is turned ON, check that the ABS
warning light goes on for 3 seconds.
If you don't get the 3 second ABS warning light, there is an ABS trouble code procedure that is described on p. 93.
Did the problem which you describe initially appear immediately after any brake maintenance or repair procedure?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
