Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - will engine swap?
View Single Post
Old 01-08-2008, 12:22 PM   #6 (permalink)
piso
prjkt:jdmidnight
View piso's Photo Gallery
hahaha, i own an ae86 and an ae102 (94 corolla) yes the motor will swap since they are both A series blocks the difference being in the head. the 4age is a true twin cam as the 7afe (the motor in the 94) is a twin cam with one exterior cam gear and one internal slave cam. since your 4age is a rwd, you will need to take one of the bearings out of the tranny but the housings and all will bolt right in (i do believe you have the T50 transmission on the 4age). if you really want to do that swap tho, i would say switch the blocks when you do it (take the block from the 7afe and put the head from the 4age on it) this basically gives you the true twin cams and more displacement on the bottom end (1.8 rather than 1.6). just make sure you swap ecu's when you do it and check all your wiring
piso is offline   Reply With Quote
