Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Question 98 Camry ECU (RS3000) programming
View Single Post
Old 01-24-2008, 04:10 PM   #1 (permalink)
K9AMRee8
View K9AMRee8's Photo Gallery
I have searched a number of areas and found most of the answers I am looking for but... From what I understand there is a button that is to be pushed on the ECU to begin the program mode (to program extra remotes). I have located what I believe to be the ecu behind the kick panel (driver's side). It is wire tied. From what I can determine it has ecu printed on it but it appears to have lass breakage sensor information printed on it as well. I see only one bundle of wires pluged in to it (top side) and it appears there is a recessed area, possible metal in the center (bottom side). I can't quiet get a clear view of the bottom to see if there is a button to push. I plan to get a mirror to try to get a better view.
I had previously called the dealer to inquire of the location of the ecu. I told the service advisor I thought there was a program switvh on the unit to start the program procedure. He advised the unit had to be programmed with a scanner...
Finally I will get to the question...
Was there a cut off production date where they changed the rs3000 where they combined the ecu and glass break sensor and removed the programming capability from the user, requiring dealer involvment or is the dealer just trying to get more of my money?
Thanks in advance.
K9AMRee8 is offline   Reply With Quote
