Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Can i put 2 connections from 1 amp to 1 sub with DVC?
View Single Post
Old 01-26-2008, 02:00 AM   #4 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Running seperate channels to each voice coil on a DVC sub is not recommended.
If you want to use a sub that has DVC, go with 8 ohm DVC and wire the coils in parallel or 2 ohm DVC and wire the coils in series. Both will result in 4 ohms.
"Skoolin' the unlearned!"
