Originally Posted by Slaughter
CEA-2006 Power Rating
CEA-2006 Power Rating (4Ohm@14.4 V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 16W x 4
Max Power Output: 45W x 4
That's the power rating for my HU. Not the best unfortunately, and I would rather spend a few bucks more for the power.
Also, while running 2 amps, I'm guessing that's 2 power leads from the battery correct? They can't properly piggyback can they?
Just trying to figure out my wiring and may redo it at that time.
Yeah, the 16X4 is what you need to go by, and there aren't many 6X9s down in that range. The Boston Acoustics that I mentioned in my post are rated 2-35W, and that's about as low as you'll find. As I noted though, my HU is only pushing 20W and they work great with that. 4W isn't that big a difference. Unfortunately, Crutchfield Canada apparently doesn't carry any 6X9s down in that range, so you'd have to find a different source if you wanted to go that route.
But yeah, if you're willing to install another amp, that gives you WAY more options on speakers. Again though, it appears Crutchfield Canada doesn't carry anything cheaper than $259 in a 4 channel amp either which seems a bit pricey. You should be able to get a good 4-channel amp for a lot less than that.
I've never been a huge fan of Infinity speakers. I've always found them a bit harsh for my taste.
Have you looked at these? They're a bit cheaper than the Infinity's and very good....
6X9s
http://www.crutchfieldcanada.com/JBL.../109gto927.htm
http://www.crutchfieldcanada.com/Pol...p/107db691.htm
5-1/4s
http://www.crutchfieldcanada.com/JBL.../109gto527.htm
http://www.crutchfieldcanada.com/Pol...p/107db521.htm
