Take off the door panel.
OVERHAUL
HINT:
- Installation is in the reverse order of the removal. But the installation is indicated only when it has a point.
- In the RH side, work in the same procedure as in the LH side.
- REMOVE POWER WINDOW REGULATOR MASTER SWITCH ASSY
- Remove the front door armrest base cover lower.
- Remove the screw.
- Using a screwdriver, remove the power window regulator master switch assembly then disconnect the connector.
HINT:</B> Tape the screwdriver tip before use.
- REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH LH
- Using a screwdriver, remove the front door lower frame bracket garnish.
- REMOVE FRONT DOOR INSIDE HANDLE BEZEL PLUG LH
- Using a screwdriver, remove the front door inside handle bezel plug.
- REMOVE FRONT DOOR TRIM BOARD SUB-ASSY LH
- Remove the hole plug.
- Remove the 5 screws.
- Remove the clip.
- Using a screwdriver, remove the front door trim board.
HINT:</B> Tape the screwdriver tip before use. - Remove the inside handle then disconnect the 2 cables from the front door lock assembly.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
